Smart Alternator and Victron XS50
ben5560
VCDS User
Quick question on the XS50, I haven't bothered connecting an ignition line to the DCDC charger, instead relying on the smart alternator detection built into the XS50. Is this a mistake? As apparently the T6.1 can allow the voltage to drop, and the XS50 can stop charging as a result?
It should work assuming all the voltage thresholds are set appropriately but an ignition (or ideally engine run) signal is potentially more reliable.
Where would you take a ignition run signal from on a t6.1 i was thinking fuse 47 but getting conflicted info any help/ advice appreciated
