Bought a remote controlled switch operates to hook on to my Eberspacher diesel heater which only has on/ off control on the controller = pain in neck if operating from sleeping position. My heater unit the D2 switches off after a couple of hours so no timer setup on it. This remote switch makes it easy to turn on/off at night time.
Anyway can be used for anything else you want to control.
Proof of concept done works fine, just got to wire it up with the switch +ve to the Yellow control wire on the heater.
The remote is programmeable for various control options ie 1 button toggle on/off, latch 1 button on and 2nd button off, latch on /off with same button and momentary action = on while button held also a delay mode available.
As usual - info might be helpful to others on the forum.
