Finally picked up ,y van today and so the process of putting the collection of parcels in the living room onto the new toy. Everything was going well until the sidebars. I chose a set with steps as the other half tends to stand on them.
From the outside photo you can see the design and you may be able to see that they are leaning slightly towards the van.
This is due to the mounting design, looking on the forum it seems different to most and has two bars mounting across the van that the bars then attach to. once mounted the space between the bars isn't big enough to fit the brackets on the side bars comfortably and I've sort of squashed them on. I shall include photos of the instructions to help you see what I've been working from.
Under the van the rear bar is mounting on the swing arm bracket. the front is where any adjustment can be made but sadly there brackets cant go any further forward. hopefully you can work out what I mean by the photos.
Is this because its a t6 and its a t5 bar? would normal fitting bars fit perfectly?
Any advice would be greatly received.
