Retrofit PDC on/off switch
T6NOMAD
@RobNomad
I have a Startline which has rear PDC but I am unable to turn off the PDC as theres no switch on the dash.
Can this switch be retrofitted?
Hi. Did you have any joy with this? I'm looking to do the same.
One option I am looking into is to use an OEM switch, and use that to turn the PDC circuit off (at the fuse box with a relay), but I'm having issues finding the pin information of the OEM switch and whether it offers latching switch pins.
Also if pulling the fuse on the PDC circuit is likely to cause any error codes.
The instructions for retrofitting PDC,. Including the wiring instructions for the switch, are in the following:
in post #7 here:
Sounds like quite a bit of work, but you might glean enough infromation for what you are trying to achieve.
