Replacement Worktop
Tanstalf
I am replacing the hob/sink worktop as the converter used 10mm ply for some reason, so the trim is off and the table snags.
Pretty sure this will be a standard size.
Can anyone recommend where to buy a replacement?
I can’t imagine your going to find a plug and play replacement as they are bespoke.
I would recommend not using plywood again, Corian is far better.
