Replacement headlights
Great, thanks. I’ve got it all working and dipped beam switched on. I’ve now got a headlamp warning light on the dash though. I’ve run a scan on the Carista and these faults have been found. Thanks for all your help with this. This forum is a must for anyone with a T6!
Are your LED DRL bulbs Canbus compatible? If not you will get the warnings. If they are Canbus compatible try starting the van an letting it charge up the battery a bit as a low battery may give you these warnings. Mine did that on the very first time I fitted them, never happened since (2 years).
Are your LED DRL bulbs Canbus compatible? If not you will get the warnings. If they are Canbus compatible try starting the van a letting it charge up the battery a bit as a low battery may give you these warnings. Mine did that on the very first time I fitted them, never happened since (2 years).
Thanks, I killed the battery earlier from working on the van all day, fingers crossed that could be the fault. Thanks for all your help with this! The MOT is on Tuesday so with any luck the lights shouldn’t be an issue. Just having ago at fitting the Vanstyle front fog lights.
You can switch off bulb warning in Carista. You won't get any bulb out messages then, just check them manually like the good old days
Thanks for the info on this. I’ve looked on the Carista and can’t see a bulb warning off option. What section would this be in? Thanks!
