Hi All,
I don't post on here much but wanted to ask the learned here, and especially Renogy owners:
I have a Fogstar 315ah 12v battery kit which i just built (and very good it is ,Great company, products and value)
I built a mobile batteryunit into a peli case with a renogy 2000w inverter and was testing it out on some household items
to see what its capable of. Everything works fine within its capacity but i tried a washing machine and thought that it couldn't
be more than a 1500w pull when the heater is on. What happened was the washing machine reported an F1 error code suggesting a short
circuit ? Obviously there was no short circuit but it didn't like the renogy inverter running it and the machine didn't cut out but refused to go further in the cycle.
So the question is is it a simple case of not enough surge power for spikes on tap ? The Renogy has a 4000w surge rating so can't imagine that.
Or something else which it doesn't like, maybe to do with the motor or circuitry in the washing machine ? The washing machine is an Indesit
about 3 years old. Running on a 30 degree cycle, if that makes a difference to power draw. The only other issue i thought was that i am running a
15m extension lead and there will no doubt be voltage drop but i didn't expect what happened.
Any ideas here on what it might be and if its a problem with the renogy type of inverter.
Thanks all
Si
Thanks all
Si
