Which trim?
Upper or lower?
The lower is quite easy, if you start on the centre panel, put your finger through the grille at the edge of the panel, just above the strip and you should be able feel the tab on the strip - try and push that out, once you have the edge started you can work from the front as well - but you still need to be quite careful. With the centre off, you do the same on either side strip.
