Afternoon all!
I'm having an issue which is driving me crazy!!
My t6 control panel from my leisure battery started recently only showing 5v rather than 12. I discovered that it's an issue with my on/off toggle switch which I've placed between the battery and the control panel. When I connect the battery direct to the panel it reads 12v and everything works fine. But with the switch there is low voltage and nothing works. It used to be fine and cannot solve the issue. I've tried a new switch and the same problem happens.
What could be causing this? Any help appreciated
