Rear Kombi Load Mat Question
N58amx
Carpeter
just picked up a rear kombi load rubber mat
And was wondering if i can buy inserts to cover load lash points?
Again , google is being a bit useless :(
Thanks nick
Can you nit buy/ use the OEM lashing point inserts then bind them in?.
Can only find them for sale , currently including the actual metal bolt down parts
Shame, as they are allready in van floor
Try a local conversion company they will remove plenty of these when fitting out campers
Is it just the plastic trims you are after ??
Kombis have a metal sleeve around the bolt between the plastic trim and the metal floor to allow for the thickness of the floor, not sure they will be present (or the same size) in a panel van ?
Someone here will prob have some they have taken out when changing floor ??
@Deaky @Fish
@StudleyGlass yoirs is coming out soon, can you help ?
Sold all mine but I know for a fact that @VWVC has boxes of these. Give colin a ring, he will sell you a few.
Thought this might be handy, top line is spacer tube for the bolt (if not already present), second line is single hole mounting trim, third line is two hole mounting trim
Prices on the end are retail plus vat
I should be at Colins @VWVC this Friday if you need me to see what he has ?
I will have a full floor/seats/belts/brackets etc. when i have finished there but i will be selling them as a full package.
