Hi,
I've a T6 shuttle camper conversion, with the Skyline conversion roof where the mid light and ventialtion bar is moved to the rear.
I've noticed recently that the courtesy lights on the rear are now on when the ignition is on, but fade out as the front courtesy lights fade in once the ignition is turned off (and key removed).
I checked the rear re-wiring this evening, and it all seems ok. The behaviour is affecting both sides of the rear light bar (they are wired independently).
Is this likely to be a BCU reset type issue or a short somewhere north of the B pillar?
Any advice welcome
Kevin
Any advice welcome
Kevin
