Rattle from Exterior Panel Behind the Sliding Door
How much sound deadening did you get behind it ? Was it just silent coat or something similar you used on the back of the panel itself ?
I didn’t go nuts, as I was concerned about whether any area would interfere with the slider. Should have taken a photo, but I was in a rush to get other stuff done too.
I basically did sections in the cut outs and on the flat bits under the clips, plus some bits on the flats between the cut outs and the lower clip protrusions.
About half a sheet at most, without wasting any bits. Sounds a lot better in fairness.
That’s a shot from the previous video and not me btw.
