Hi,
I have a limited understand of electricity and was wondering if someone could answer this.
I recently bought a radio control car of my boy, (had to get a second one for my 1 year old which I will look after till he is big enough to drive it...)
The charging setup is something I have never seen before.
It charges via usb, the instructions say that it should be charged at between 0.7a-2a (5v obvs) I was always under the impression that current is "pulled" from the power source so you can use a more powerful charger providing the voltage is correct?
Image of the battery is below, it has one wire for charging and one for providing power to the car
Here is the funny bit
If I used a 2 port charger which has a max output of 2.4a how close to danger am I getting?
Thanks in advance
- It charges at 5v , 0.7a-2a
- However the battery is 7.4v,1800mAh, 13.32wh
- Switch on car 7.4v 45w
Thanks in advance
