I build in a new radio and i can not find the fuse.
I had a little shortcircuit and now i need to find the fuse. Its for the red wire, on yellow cable i still have +12v
I found the fusebox below the dashboard but cannot find it.
I had the same when working on the interior lights . The fuse was fine but it had been cut off in the ecu . A fault code reader showed up a code related to the lights and after resetting the fault it came back on .
