Power Management System
Razorbrown
I have just noticed that my battery indicator light for the leisure battery on the power unit has come loose and pushed itself into the unit. Any thoughts on how to fix it?
What power management system do you have. Got any pics
Perhaps undo the 4 screws you can see and investigate further, it probably clips into a cage.
Looking at the attached video
when supplied new the front panel is only held onto the cage by two small cable ties so if you remove the four screws as Deaky says then the front cover should come away
