Porte latérale probleme poignées T6
martial57100
Bonjour j'ai un problème, enfin deux problème avec mes poignées de porte latérale sur mon multivan T6 de 2016 .
Elles sont très difficiles à ouvrir , est ce que quelqu'un a déjà eu ce soucis et si oui comment l'a t il résolu.
Merci d'avance.
Martial
Hello, I have a problem, or rather two problems, with the side door handles on my 2016 T6 Multivan.
They are very difficult to open. Has anyone else had this problem, and if so, how did they resolve it?
Thanks in advance.
Martial
Hi martial
Do you have more details? Is the problem unlatching the door (when the door moves out) or sliding the door to the side? Are they electric opening or manual? Is the problem the same on both sides?
With more info and maybe photos people are more likely to be able to help
Salut désolé pour le manque de détails le problème vient à l'ouverture de l'exterieur ou de l'intérieur, c'est une ouverture manuelle et il faut tirer fort pour pourvoir l'ouvrir.
“Hi sorry for the lack of details the problem comes when opening from the outside or from the inside, it is a manual opening and you have to pull hard to be able to open it.”
The gentleman only has French? You are comfortable with French cgtmiles? You seem to be doing OK!
I’m more comfortable with French than most other languages but still pretty poor with that, Google translate is my friend.
So what would stop a door opening, assuming the handle is working correctly could the issue be with the rear swinging/rolling mechanism? Nobody had this issue?
Probably the bottom roller bearing has seized so instead of rolling you're dragging the whole weight of the door along the bottom runner. or even worse the bearing has collapsed is dragging along the metal of the bodywork.
Put your hand up under the bottom door bracket and feel the roller and move the door slightly and feel if the roller rotates or not.
It's a cheap and easy replacement.
Some good pictures and a video in this thread.
Bonjour, merci pour cette information j'ai vérifié mais ce n'ai pas ça. Le problème vient plutôt de la poignée ou du système d'ouverture, elle fonctionne mais ne se déclenche pas l'ouverture. Il faut tirer fortement sur la poignée pour pouvoir ouvrir l'ouverture. Si quelqu'un connaît le fonctionnement, j'ai vu une vidéo ou quelqu'un a resserré un câble dans la glissière supérieure mais je n'arrive pas à démonter la tole de protection qui est en place. Si vous avez des infos merci de me partager.
Bonne journée à tous.
Martial
