Hi all,
I've had the passenger door card off my T6 today, all seemed to go back together fine but on closing the door I can no longer open it from the inside or outside. Inside handle doesn't feel like there's much resistance.
1. Central locking seems to be working, pin goes down and back up and I cant pull it any further up it sounds as though it's unlocking the door
2. I've removed the external handle and pulling on the cable from outside doesn't work
I've read some other threads that reckon that if the inside handle is pulling any tension on the cable, the outer handle wont work, there's a good chance the cable isn't connected or the actuator mechanism is jammed somehow.
Obviously with the door shut, I cant get access to remove the door card (the two 90 degree plastic clips at the bottom are not accessible) so kind of knackered until I get access.
edit - I've just found another thread showing removal of the door card so I'll give that a go and see what has gone wrong
