Will give it a degrease over the weekend and see if anything appears. It’s a bit odd that it looks like very clean oil ( or something else) thanks for the advice thoughlooks like a leak to me, but very slights at this stage?
if that was a leak, it maybe the - crankshaft oil seal. ( behind the flywheel )
a big job as the flywheel (DMF) needs to come off ( and normally replaced)
was that pic from the video they sent you? - can you post a link to the vid?
but good advice above - use break clean to clean it all off.
then monitor once a week to see if it come back / how bad.
I took the under tray off yesterday randomly. Still leaking slowly. Still trying to work out what to do to be honest! Ultimately gear box needs to come out.. clutch and flywheeel.. vw think it’s either flywheel bolts or oil seal.. the van has only done 35k! So crazy that oil should be leaking at this mileage!Any update on this? I may have a leak in a similar location.
My DPF light can on yesterday (but off again today)), and found I have found a leak which looks similar to yours.Went to the stealers today and they mentioned a potential oil leak between the engine and gearbox. That to me don’t look like old oil if it is oil. Any thoughts ?View attachment 193947
That looks like engine oil from the sump plug, clean it off and watch where it leaks from.View attachment 208962
What happened with your issue in the end? Any advice gratefully received!!!
That was what I thought it could be. It was only serviced a few weeks ago. I’ll have a good look at it tomorrow. Thanks DXXThat looks like engine oil from the sump plug, clean it off and watch where it leaks from.
If you are going to check if the plug is loose be careful as the person who last tightened it may have stripped the thread.That was what I thought it could be. It was only serviced a few weeks ago. I’ll have a good look at it tomorrow. Thanks DXX
I might just pop in and get them to look at it. It looks like it’ll be their fault anyway!!If you are going to check if the plug is loose be careful as the person who last tightened it may have stripped the thread.
That's definitely just the sump plug leaking. From the photo, looks like there might be 2 soft steel washers on it? Should only be the one.I might just pop in and get them to look at it. It looks like it’ll be their fault anyway!!
Looks like the crankshaft seal is weeping from behind the drive pulley. Isn't that a common issue? Not too bad to fix at the next cambelt change?some oil leaks shown on my van . . .
@Dellmassive`s T6 T32 Sportline 204 LWB DSG PV MY18 - Van Adventure
@Dellmassive`s T6 T32 Sportline 204 LWB DSG PV MY18 - Van Adventure as you all know my main contribution to the Forum is my "How i Done It" threads, over here: ++++ https://www.t6forum.com/threads/dellmassive%E2%80%99s-how-i-done-it-blogs.8510/ ++++ which is great and well, but i...www.t6forum.com
View attachment 193951View attachment 193952
VW have changed the cam belt interval to mirror Europe - could be a long wait!Looks like the crankshaft seal is weeping from behind the drive pulley. Isn't that a common issue? Not too bad to fix at the next cambelt change?
