New battery and alternator, van won't start
After I limped it home I tried to see if it would restart and it was cranking and not firing then... So Im no further along really. The new alternator I put on was just my old one that was reconditioned by a local firm. I'm alright with spanners but a spanner with tech. I'll get someone out👍
It's got a leisure battery fitted, seen something about a hard reset and disconnecting it.... Might give that a go...
Just to add 2019 t6.1
Which one - 2019 or T6.1, can't have both.
Which engine exactly - engine code please - something like CXGA, CXGB, CXHA,....
P056200 system voltage engine fault
Is this a current fault or just a thing of the past. Does it clear? Does it come back?
Can't comment in obd11 for reading the engine computer data?
@mmi any joy with obd11?
Yes, it can be of some help. All ECU data is available - when you know whar to look for. However VCDS would save A LOT of time, and probably money, too.
If the fault P0562 has been cleared/resolved:
OBDeleven > Contorl Units > Engine > Live data​
1) Check camshaft timing offset > Camshaft adaptation intake bank 1, phase position
2) Verify fuel pressure build up when cranking > Fuel pressure
3) Verify the ECU fires the injectors when cranking > Main injection, duration of activation
