Need slidepod help
Linoleum Bonypart
Hi …. Just installed the slidepod and there was no user handbook … my sons taken it away now to Scotland and can’t find tap for the waste water tank … hopeless aren’t I ….anyone help ??
It's on the under side, rear left corner. Pull the pod out and twist. You probably need to be on a bit of a slope. It's closed when the cap is aligned with the direction of the van. Will PM you the manual.
Would you mind sending me manual as im having same problem thanks
