Mystery hose.
The Tangerine Dream
Hello all,
I've been doing a bit of work on the van (see my ongoing thread about blocked Cat/DPF).
Anyway, I've come across this hose which I've never seen before!
Possibly a clue, but I also have these VCDS readings since funding it:
16409 - Actuator Module for Turbocharger 1
P00AF 00 [01100000] - Stuck
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 286225 km
Date: 2102.01.12
Time: 00:01:28
Engine speed: 1030.75 /min
Normed load value: 15.7 %
Vehicle speed: 0 km/h
Coolant temperature: 21 C
Intake air temperature: 16 C
Ambient air pressure: 970 mbar
Voltage terminal 30: 12.468 V
Turbine actuator 1 bank 1: posit.feedback - Specified value: 100.00 %
Turbine actuator 1 bank 1: posit.feedback - Actual value: 15.13 %
Turbine actuator 1 bank 1: posit.feedback - Offset closed: 2.64 %
Turbine actuator 1 bank 1: posit.feedback - Raw voltage: 3.777 V
Accelerator pedal travel: raw value: 0.00 %
16261 - Turbocharger Boost Control Position Sensor Circuit
P2563 00 [01100100] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 286225 km
Date: 2102.01.15
Time: 18:42:49
Engine speed: 843.25 /min
Normed load value: 39.2 %
Coolant temperature: 20 C
Intake air temperature: 12 C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.578 V
Turbine actuator 1 bank 1: posit.feedback - Specified value: 99.46 %
Turbine actuator 1 bank 1: posit.feedback - Actual value: 15.00 %
Turbine actuator 1 bank 1: posit.feedback - Raw voltage: 3.772 V
Readiness: N/A
Any ideas?
Cheers,
- TTD
