I have a 2016 T6 TDI DSG. I last drove it on Wednesday with no issues. I went to start it on Friday morning and got a warning sound, Airbag error message, and several/all dashboard lights flashing. The engine did start, but cuts out as soon as I put it into gear. I ran it through Carista and with the range of errors that have all happened at the same time, along with missing sensor info and odd reporting, it definitely seems to be an electrical fault.
I asked elsewhere and somebody suggested something has chewed the cables underneath. I can't fully get under until I can borrow my friends trolley jack, but I managed to get a camera under and to me, the cables look fine. I know this could probably be anywhere, but on the off chance anyone's had the exact same errors, can anyone point me closer to the issue?
Basic OBD2:
U0121 (Pending) - Lost Communication With Anti-Lock Brake System (ABS) Control Module
CAN network gateway:
01316 - ABS control module: No signal/communication
Freeze frame
Priority: 2
Malfunction frequency counter: 1
Unlearning counter: 75
Odometer reading: 167533.4 miles
Engine:
U012100 - Lost Communication With: Anti-Lock Brake System (ABS) Control Module
Freeze frame
Priority: 2
Unlearning counter: 255
Engine rpm: 0 RPM
Normed load value: 0 %
Vehicle speed: 158.4 mph
Coolant temperature: 22 °C
Intake air temperature: 18 °C
Ambient air pressure: 14.65 PSI
Voltage terminal 30: 12.16 V
Transmission:
U112100 - Databus missing message
Freeze frame
Priority: 0
Engine rpm: 0 RPM
Engine torque: -36 Nm
ATF temperature: 17 °C
Accelerator pedal position: 14.8 %
Coolant temperature: 215 °C
Selected gear: GANG_UNDEFINIERT
Airbags:
U112200 - Databus implausible message
Freeze frame
Priority: 6
Instrument cluster:
U111100 - Function restriction due to missing message
Freeze frame
Priority: 6
Heater & air conditioning:
Freeze frame
Priority: 6
Malfunction frequency counter: 4
Parking/steering assist:
Freeze frame
Priority: 6
Basic OBD2:
Freeze frame
Priority: 2
Engine:
Freeze frame
Priority: 2
Engine rpm: 0 RPM
Transmission:
Freeze frame
Priority: 0
Engine rpm: 0 RPM
Airbags:
Freeze frame
Priority: 6
Instrument cluster:
Freeze frame
Priority: 6
Freeze frame
Priority: 6
Freeze frame
Priority: 6
