Sonniemacc
Hi I’ve had a ‘slight’ problem with some leisure battery wiring. This wire runs from my starter battery via a fuse to my b2b charger, it’s 8AWG wire which I thought should be more than enough to carry the current (roughly 3m).
It looks like the wire has got so hot that it melted through the insulation and melted the battery casing. No idea how this has happened so would love some suggestions but my best guess is a bad connection of the ring connector to the terminal? Admittedly the connector wasn’t fit very well to the terminal and should really have been in its own threaded stud so maybe it was arcing?
It’s worth me adding this didn’t happen for over a year until recently I upgraded to a Lithium leisure battery which can be charged at 20A instead of the average 6A or so my Lead acid was being charged at. Perhaps this increase in current with the bad connection has resulted in this?
Any other thoughts?
Any other thoughts?
