Found Lower Grill 3 Piece Trims
Northern Monkey
T6 Legend
As the title says I’m after the 3 lower trims anyone who’s upgraded to the chrome trim got a set they want to off load?
Well drawn a blank :( come one there must be someone out there with them collecting dust in their garage.
Hi NM
Why do you need trims, has somebody stolen them?
Steven
I thought that was the case.
I wrapped mine, honestly, its dead easy and if you make a mistake you can usually rectify it.
Otherwise, like the song.
" Rip it up and start again " :)
I've done the trim your on about, also behind front badge and lower mirror covers, which were the hardest.
Keep the area clean, put some relaxing music on and pinch the Mrs's hairdryer.
Honestly, once the vinyl is heated up, it stretches anywhere, you can even remove a section, heat it then reapply, to iron out bubbles or lines many times over.
This is the stuff i bought, cant fault it.
30 cm wide, 150 cm long.
For around £4 delivered, you've got to have a go.
2D 3D 4D Carbon Fibre Vinyl Wrap 300mm(11.8in) x 1520mm(59.8in) Bubble /AIR Free | eBay
Steven
A3E65522-8174-4205-A302-46AB1C62F543.jpeg Cheers fella I’ve wrapped mine was looking at something a bit more permanent, think I’ll not bother and just stick with what I’ve done.
Thanks for the link ;)
