long time listener
jamas
Hi All
I know its not the done thing but im having some major grief!!
Changed the rear light and fog)bulb on my t6 and lost my dash lights/headlights/wipers/fan blower/indicators/Engine will turn over but only run for a second!! can anyone help?
Many Thanks
First thing to do is check fuses. (Lower dash sc fuse box)
Download section has a collection of fuse layouts.
Make sure all fuses are in correct slot.
It can be easy to put one in wrong slot.
Also once fuses confirmed.
Try ECU reset...
Tried the reset still no go. Plugged in to the obd getting error u0155 instrument panel not communicating
Just to clarify...
What is now NOT working?
Engine cutting out may be due to no coms with dash clocks as they are part of the immobiliser system.
Last time we say this it was a blown fuse . . . AND a fuse in the wrong slot....
Can you take some closeup pics of the sc fuse box.?
Top left 5 Amps - Dash panel insert. Is a candidate for no comms.
had a auto electrician out he has gone through every fuse and relay and all are good,
loads of faults thrown up from ecu ecm and other modules but he could not clear the faults with his diagnostic computer. Is a VAG COM/VCDS the only way to clear fault codes
Actually any tool clears the faults, more sounds that there are faults that just come immediately back as the root cause still exists. I don't think VCDS could do any better. Did you get a listing of the persistent faults/codes?
No I didn’t most were communication codes starting with a U. Think it needs a VW specialist? Anyone know of a good one around North London??
Hi Guys
Thanks for all you advise but I had to bite the bullet and pack her off tho the dealers!!!60DF49F4-A8EE-4F1C-9B91-90A2E96B4429.jpeg
  • Sad
Reactions: mmi
