Big thanks to @Pauly for the rear lights and plugs, well happy with them, instructions perfect too,
Little tip for feeding the wires through, use a bit of plumbers solder!
I was the same @PukkaT6 but sometime you gotta just bite the bullet, so pleased I did, transformation in crazy just on a set of lights, kit was so well prepared too.
Even added a cheeky engine cover @superflyguy yes rude not to on a dark van
If vw could be bothered to fit something decent in the first place I wouldn't be thinking of changing ! I could do with changing the headlamps to h7s too so looking at nearly £1000 for front and rear !!
If I were you @superflyguy id do the rears now and see what decent aftermarket fronts come up next year.
I've changed the bulbs in my h4s to the Phillips racing bulbs and they have made a noticeable difference.
