Hi all,
I need a bit of help here, I have fitted some led strip lights in the rear of the van but the behaviour is a little strange.
I have connect a perm 12v from the leisure battery and a switched ground through a 2 way switch which switches either perm ground from the leisure battery or door ground from the factory fit ceiling lights.
Behaviour I see is
1. Switch set to switched ground, I open the door, the lights flicker but don’t come on
2. Switch set to off ie no ground I open the door and move the switch to switched ground the lights come on
Why is this? And how do I get 1 to work? My led boot lid light is wired the same way and works so I’m guessing maybe my controller is pulling too much current? Can I fix this?
3. With the engine running Or within a few min of switching off if I switch to perm ground for the lights the controller shuts down, I’m guessing over voltage? Any ideas?
Justin
Behaviour I see is
Justin
