Just a quick one. On the roof fixings, is it just the threads that let water in? The Thule footpack I have doesn’t allow for sealing/covering the whole hole as you bolt though a rubber foot then attach the rest to that.
There is a hole and a captive nut below the hole but it isn't a sealed application. You need to bung sealant in to the hole regardless of roof rack, or rail. Even the blanking nuts with rubber gaskets should have a bit of sealant on in my opinion. Belt and braces!
That’s where I’ve gone wrong then - always thought it was just tracking the threads! So basically fill the entire hole with as much sikaflex as I can and probably the bolts!
Right…I’ve sealed the gaps around the captive nut and liquid PTFe on the screws! Fingers crossed for no leaks! Or at least almost no leaks as I think no leaks would be asking too much!!
Any water ingress from here onwards will be from faulty windscreen seal tracking up your a pillar (unlikely), leaking sluding window, or it'll be door seals and/or carpet lining folded round in door seal.
