Leaky tailgate.
JDC
I've just opened my tailgate to fund a leak coming from the inside panel. Is this a common VW leak area. Its something I've not noticed before and it doesn't look new compared to the OEM sliders. Any suggestions where this could be coming from before I take off the panel.
Check the high level brake light.
I had a reversing camera fitted (the one combined into the high break light) and it wasn't sealing as well as the OEM unit so had to mastic seal.
Also I think the pull handle assembly is another potential leak point on the tailgate.
Brilliant, ill have a look at the thread. Im off work tomorrow so I'll investigate and look at those areas and let you know. 👍
Just had this problem on my 2021 Kombi. All the drain holes are plugged! Gonna remove the plugs to let the water out. Think I may have got water inside when I left the tailgate up in the rain the other day and it may have got in through the handle??
