Ok update incase anyone searches in the future and might give some useful insight. (Sorry for detailed post but take the bits from it you wish). Ordered the THQ seal as I’ve got a trade account with them. Seal arrived next day
and usual THQ slick service. For those interested I’ve attached a photo of the OEM seal profile against the THQ. ( The OEM is the one with the rusty metal clip)
My carpet was slightly damp in the isolated area of the N/S profile next to the threshold trim as shown.
I took off the old seal and (I believe) the issue was caused by water tracking down the inside of the seal (the bit where the metal clip is) because there was shed loads of moss and crapola trapped behind it.
. The water then collected in the corner and got sucked up by the carpet. (Followed advice on here and trimmed the carpet back slightly in the corner so it did not touch the panel lip). Clean it all off and while I was at it took the rear lights out and cleaned behind them too and checked the seals.
New seal is a doddle to fit. But, my advice is try and use a solid thump with your hand rather than a mallet as if you drive the seal on too hard you tend to start splaying the metal former apart which weakens the seal and contact patch. (Experience on other seals).
A quick trim with a cutting disc (to remove excess) and seal complete. Rather than leave a two inch gap between the edges (which mine had from factory) I butted the seal together. My other ‘theory’ is during jet washing, driving in torrid rain, is that some water finds its way in an sits under the plastic trim. It then goes to the corners on top of the spit welded seam and just soaks into the carpet. Unless you are to remove the trim periodically you’ll not spot it. (Again I deduced this from where I found water traces). TBF I must have only had a desert spoon of water I reckon but enough to leach into the carpet and make you think the worse.
Rained for two days since and seal is
Also I’ve noted that my tailgate now closes fully 100% of the time. I’ve got soft close and with the OEM seal if you just let go of the TG when it was nearly shut (ie a bit gentle with it) it would only half latch and basically be ‘ajar’ and rattle. With THQ seal really positive and hard latching. (Might just be down to fitting but there you go).
Now the extra bit….
I moved over the storage unit and whipped off back 1/4 panel. Checked to ensure roof bolts all good and there was no major leak. All good as I’ve sealed with Industry Standard liquid PTFE. Anyhow I did find a small amount ( about a tea spoon) of water in the bottom of the inner rear cavity by the slam vent. A good look shows I’ve got a bit of water weeping in past the seal. (There are other posts on here regarding this hence why I looked). Courtesy of my wife’s Dyson hair dryer (don’t tell her
) I dried it out and so little water/moisture only took about 5 mins. Then got some Bilt-Hamber Cavity wax with rust inhibitors in it and sprayed a load in the void. There was a tiny (I mean minuscule) bit of surface rust mostly from bits of metal swarf I’d imagine where I’ve drilled for cables etc as it appeared to be sat on top of the factory wax. But belt and braces it got a good dose of wax to back it up.
For context mine is 38 months old (mine from new) with 15k on it.
To the morale of this long post, I strongly urge you to check the slam vents after a few years. I plan to buy some new ones and fit them in the summer (bumper off job when it’s dry and warm) and there is a post on here (can’t recall who) but v. useful about backing up the OEM slam vent seal with slikaflex, which I will do.
Didn’t check O/S but I’ll renew in summer too. I’m not worried for the moment as it is soooooo minor, but left unchecked 5 -8 years later who knows.
II think possibly some is self inflicted with the jet wash. There’s me thinking I’m being good washing all the muck off underneath. I thought (as I know the vents are there) that I was being careful in that vicinity but perhaps not so. (Note to self-Further care required).
I would not have expected at this age and mileage to have an issue but there you go.
Just thought I’d share.
As always great advice on here if you search and a great wealth of experience so keep it coming
