I have a fairly standard new T6 conversion with a solar panel, CTEK 250SE & Sargent EC155 / EC51. It recently started to show a problem.
When I switch the van electrics on via the EC51 control panel, sometimes it comes on perfectly, and sometimes comes on at low voltage (showing 6 -7 volts on a 12V socket monitor) - under this condition the van lighting will not come on or will come on dimly. If I switch it off and back on again (maybe a few times) via the control panel, then it will come back to normal operation. If I use the control panel to select the vehicle battery, I see the same behaviour - ie if it is normal, then the vehicle battery gives me normal operation, if it is in its faulty low voltage mode, then the voltage remains low.
The fridge & the heating which are independent come on normally under all conditions.
My thoughts are:
It is not a battery or charging problem - or else it would not come back on normally operating the on/off on the control panel and I would not see the same behaviour with the vehicle battery.
It could be an intermittent electronics failure in either the EC51 or the EC155 (maybe a solid state relay failing or something similar)
It could be an iffy connection to or from the EC155 or maybe a poor ground connection somewhere - this feels less likely as I am moving nothing when I switch the control panel off & back on again - also - I don't fancy the idea of having to chase down wiring behind all of the nicely finished paneling.
I tried asking Sargent & they suggest that it could be a connection issue between the leisure battery & the EC155 - but that would not explain why it can come back to life by turning the EC51 off & back on - or why I also see the issue with the vehicle battery (I probably did not give as much detail when I asked Sargent).
Does anybody here have experience of such a fault? - my next steps are going to be to swap out the EC51 & the EC155 - which is not going to be cheap - so it would be nice to think I'm not going down a blind alley.
Thanks in advance
Keefe
My thoughts are:
Thanks in advance
Keefe
