(vw t6 2019)
It appears that the heat from my heater has stopped working producing warmth. The heater continues to blow cool air and the AC works as it should.
(vw t6 2019)
It is not an uncommon occurrence! One of the potential problems and remedies is attending to the heater controls and someone has Plastic Printed a very good fix and at good price
Hi - If you look under here you can get your eyes on it. When you change the temp control the motor will adjust and you can hopefully spot if the linkage is broken.
Have a flick through some of the relevant threads on this forum for a fuller picture:
I am not a mechanic so no the best person to advise you, others on here will be able to do that. First I would read any relevant threads and posts and see if your heater problem appears to be similar or the same or have it looked at by a VAG specialist or other trusted garage. Then if it is and you feel it is not your thing to do the work ask the garage to do the work but use the part as advertised on the forum. Their are many more competent members on here who can give the initial advice.
