I prefer them. On low beam, the outer H7s are lit (55w x 2) and on high beam, the inner and outer H7s are lit, so you have 4 bulbs (55w x 4) in four separate reflectors lit. The DRLs are strips below the low beam headlight reflector.
On the H4’s, the DRLs are the large reflectors nearest the grille, and the headlights are on the outer edges of the light and give you 55w x 2 on low beam, and 60w x 2 on high beam.
The only caveat is that you will need someone with VCDS and the relevant knowledge to code H7 lights to your van, otherwise when you use high beam, the low beam will switch off.
From your profile photo, you appear to have H4’s
Spaghettiboy78
