Gladen appearance t6 8” set
Pal19
Hi,
Just wondering if anyone could help.
I’m looking at buying the gladen set for my t6.
I can only seem to find the 8” set for the t6, so I wondered if these would fit directly into the original space and would I require a amp as well or would the original head unit be ok for these. Long term I will probably upgrade but short term I’ll use without if possible.
Thanks in advance
Hi,
Thanks in advance
Better with an amp but work fine
without. I intend to buy the small hidden plug and play amp from Absolute5 to run them.
They are supplied with collars to fit them into the T6 doors.
The whole kit is designed specifically for the T6
Thankyou 👍🏼
Once you’ve decided on the amp I’d be interested to know what you’ve gone for as it’s something I’ll want going forward too. If it’s small and discreet that would be perfect
Thanks again
Had mdf previously and they just rot......make sure you add a water guard as they are wet doors
Thankyou 👍🏼
Thanks again
I’ve not got an amp for the Gladens yet.
Absolute5 recommended a small amp that’s fits in the dash I think as I don’t have anywhere else to put one. So will buy that soon.
I’ve managed to shoe horn an amp/sub combo under my seat on top of the diesel heater pipes.
It’s the phoenix gold 8” under seat one I’ve got and it works pretty good. But have measured up and can squeeze in the 10” more powerful version so intend to upgrade to that also.
Gladen do a small DSP amp and sub you can add to the Gladen speakers which is spot on.
