Genuine T6 rear LED lights
T6dder
Web/graphic designer
What is the deal with fitting the genuine LED tail light set aftermarket?
Is it as complicated as the front?
I looked in to this and got the impression they are a straight swap but have been unable to confirm this 100% as yet.
They are physically identical so will plug in and attach ok, my concern would be canbus errors, the description translated from German reads "No registration or ABE needed as serial parts" and they are listed as only suitable for vehicles from November 2015 onwards, your looking around £425 per pair minus your supporters 5% discount so around £400 for both to your door but as i said not 100% positive at this moment they will work little more investigation required unless you want to be the guinea pig and lead the way
