Workshop manual?Is that the control unit in pics
Please post the followingp24b3 and p2463.
Morning, I could only read blockfiles with marking CAN. I dont know if this is correct? Attached filesThank youWorkshop manual?
CXEB CXFA CXGA CXGB CXHA CXGC CXHB
- Loz
- cxeb engine cxfa engine cxga engine cxgb engine cxgc engine cxha engine cxhb engine manual
- VW Manuals
1) Full VCDS Auto-Scan2) Engine blockmap - Ignition ON/engine OFF3) Engine blockmap - Engine running at idle
How-to create a blockmap file:[VCDS][Applications]- Single Controller Address = 01- Login or security access code: Leave blank- Function: Measuring values- Output: CSV file[Go]
The result (TXT and CSV) files are saved into dircetory C:\Ross-Tech\VCDS\Logs
Please attach the files here.
Possibly your VCDS cable is an older one (9+ years) as they can't read data of controllers using UDS protocol - as T6 engine?Morning, I could only read blockfiles with marking CAN. I dont know if this is correct?
Wherefrom is this?The soot content is 72%
Obviously - because ECU thinks the DPF is overloaded with soot - as it seems DPF regeneration haven't happen for a while. Normal distance between DPF regens happen every 200-300 km. The limit for soot mass is 45 g.it won't accept forced regen.
23902 - Particle Filter
P2463 00 [10101111] - Excessive Soot Accumulation
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 192031 km
Date: 2110.01.22
Time: 01:28:32
Engine speed: 974.25 /min
Normed load value: 21.6 %
Vehicle speed: 0 km/h
Coolant temperature: 93 C
Intake air temperature: 19 C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.773 V
Unlearning counter according OBD: 40
Counter for regeneration time of particulate filter: 407 s
Particle filter: kilometers since last regeneration: 6553.5
Particle filter: soot mass measured: 59.97 g
Particle filter: soot mass calculated: 60.00 g
Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: 0.7 mbar
Particle filter: field regeneration lock status: 8
Thaank you very much for your time. aprichieted. Probably change dpf then?Possibly your VCDS cable is an older one (9+ years) as they can't read data of controllers using UDS protocol - as T6 engine?
Only HEX-V2 and HEX-NET have the UDS capability.
Wherefrom is this?
(snippet below from attached fault listing)
Particle filter: kilometers since last regeneration: 6553.5Particle filter: soot mass measured: 59.97 gParticle filter: soot mass calculated: 60.00 gCode:23902 - Particle Filter P2463 00 [10101111] - Excessive Soot Accumulation MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 1 Mileage: 192031 km Date: 2110.01.22 Time: 01:28:32 Engine speed: 974.25 /min Normed load value: 21.6 % Vehicle speed: 0 km/h Coolant temperature: 93 C Intake air temperature: 19 C Ambient air pressure: 1000 mbar Voltage terminal 30: 14.773 V Unlearning counter according OBD: 40 Counter for regeneration time of particulate filter: 407 s Particle filter: kilometers since last regeneration: 6553.5 Particle filter: soot mass measured: 59.97 g Particle filter: soot mass calculated: 60.00 g Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: 0.7 mbar Particle filter: field regeneration lock status: 8
| IDE07528-MAS12283 | Coordinator releases for DPF regeneration-Components and systems fault-free | Condition met |
| IDE07528-MAS12284 | Coordinator releases for DPF regeneration-Tank level > Min. limit | Condition met |
| IDE07528-MAS12285 | Coordinator releases for DPF regeneration-Time after engine start: start driving > Min. the limit | Condition met |
| IDE07528-MAS12286 | Coordinator releases for DPF regeneration-Min. limit < driving speed < max. limit | Condition met |
| IDE07528-MAS12287 | Coordinator releases for DPF regeneration-Power connection | Condition met |
| IDE07528-MAS12288 | Coordinator releases for DPF regeneration-Lowest gear: no gear shifting | Condition met |
| IDE07528-MAS12289 | Coordinator releases for DPF regeneration-Oxygen sensor before NSC operational and fault-free | Condition met |
| IDE07528-MAS12290 | Coordinator releases for DPF regeneration-Oxygen sensor after NSC operational and fault-free | Condition met |
| IDE07528-MAS12291 | Coordinator releases for DPF regeneration-Ambient pressure > Min. limit | Condition met |
| IDE07528-MAS12292 | Coordinator releases for DPF regeneration-Min. limit < ambient temperature < max. limit | Condition met |
| IDE07528-MAS12293 | Coordinator releases for DPF regeneration-Control module temp. < Max. limit | Condition met |
| IDE07528-MAS12294 | Coordinator releases for DPF regeneration-Fuel temp. < Max. limit | Condition met |
| IDE07528-MAS12295 | Coordinator releases for DPF regeneration-DPF fault-free | Condition met |
| IDE07528-MAS12296 | Coordinator releases for DPF regeneration-Metering release for SCR | Condition met |
| IDE07528-MAS12297 | Coordinator releases for DPF regeneration-Smoke limit inactive | Condition met |
| IDE07528-MAS12298 | Coordinator releases for DPF regeneration-Soot mass < Max. limit_1 | Condition met |
| IDE07528-MAS12299 | Coordinator releases for DPF regeneration-Soot mass < Max. limit_2 | Condition met |
| IDE07528-MAS12300 | Coordinator releases for DPF regeneration-Min. limit < engine speed < max. limit | Condition not met |
| IDE07528-MAS12301 | Coordinator releases for DPF regeneration-Water quantity in charge air cooler < Max. limit | Condition met |
| IDE07528-MAS12302 | Coordinator releases for DPF regeneration-Internal torque < Max. limit | Condition met |
| IDE07528-MAS12303 | Coordinator releases for DPF regeneration-Internal torque > Min. limit | Condition met |
| IDE07528-MAS12304 | Coordinator releases for DPF regeneration-Min. limit < internal torque < max. limit | Condition met |
| IDE07528-MAS12305 | Coordinator releases for DPF regeneration-Dynamic internal torque < Max. limit | Condition met |
| IDE07528-MAS12306 | Coordinator releases for DPF regeneration-Positive control deviation motor filling < Max. limit | Condition met |
| IDE07528-MAS12307 | Coordinator releases for DPF regeneration-Negative control deviation motor filling > Min. limit | Condition met |
| IDE07528-MAS12308 | Coordinator releases for DPF regeneration-Min. limit < temperature after charge air cooler < max. limit | Condition met |
| IDE07528-MAS12309 | Coordinator releases for DPF regeneration-Min. limit < engine temperature < max. limit | Condition met |
| IDE07528-MAS12310 | Coordinator releases for DPF regeneration-Min. limit < combustion chamber temp. < max. limit | Condition met |
| IDE07528-MAS12311 | Coordinator releases for DPF regeneration-Combustion chamber temp. < Max. limit | Condition met |
| IDE07528-MAS12312 | Coordinator releases for DPF regeneration-Temperature before turbine < Max. limit | Condition met |
| IDE07528-MAS12313 | Coordinator releases for DPF regeneration-Temperature after DPF < Max. limit | Condition met |
| IDE07528-MAS12314 | Coordinator releases for DPF regeneration-Temperature after oxi cat. < Max. limit | Condition met |
| IDE07528-MAS12315 | Coordinator releases for DPF regeneration-Temperature after oxi cat. < Min. limit | Condition met |
| IDE07528-MAS12316 | Coordinator releases for DPF regeneration-NSC temperature < Max. limit | Condition met |
| IDE07528-MAS12317 | Coordinator releases for DPF regeneration-NSC temperature < Min. limit | Condition met |
| IDE07528-MAS12318 | Coordinator releases for DPF regeneration-Virtual temperature | Condition met |
| IDE07528-MAS12611 | Coordinator releases for DPF regeneration-Value | |
| IDE07528 | Coordinator releases for DPF regeneration |
Fuel level above 1/4 is not true. My van can start e regen with the fuel in the red zone.There are a number of criteria that must be met to do the regen - engine temp, fuel level (above 1/4), no Fault codes present, soot level not too high (above 40g maybe).
If you can trick the van to think everything is met then it might work
This is the list on my van for a standard regen, so probably doesn't need all of them for a forced regen. I'm sure MMI will add more information.
IDE07528-MAS12283 Coordinator releases for DPF regeneration-Components and systems fault-free Condition met IDE07528-MAS12284 Coordinator releases for DPF regeneration-Tank level > Min. limit Condition met IDE07528-MAS12285 Coordinator releases for DPF regeneration-Time after engine start: start driving > Min. the limit Condition met IDE07528-MAS12286 Coordinator releases for DPF regeneration-Min. limit < driving speed < max. limit Condition met IDE07528-MAS12287 Coordinator releases for DPF regeneration-Power connection Condition met IDE07528-MAS12288 Coordinator releases for DPF regeneration-Lowest gear: no gear shifting Condition met IDE07528-MAS12289 Coordinator releases for DPF regeneration-Oxygen sensor before NSC operational and fault-free Condition met IDE07528-MAS12290 Coordinator releases for DPF regeneration-Oxygen sensor after NSC operational and fault-free Condition met IDE07528-MAS12291 Coordinator releases for DPF regeneration-Ambient pressure > Min. limit Condition met IDE07528-MAS12292 Coordinator releases for DPF regeneration-Min. limit < ambient temperature < max. limit Condition met IDE07528-MAS12293 Coordinator releases for DPF regeneration-Control module temp. < Max. limit Condition met IDE07528-MAS12294 Coordinator releases for DPF regeneration-Fuel temp. < Max. limit Condition met IDE07528-MAS12295 Coordinator releases for DPF regeneration-DPF fault-free Condition met IDE07528-MAS12296 Coordinator releases for DPF regeneration-Metering release for SCR Condition met IDE07528-MAS12297 Coordinator releases for DPF regeneration-Smoke limit inactive Condition met IDE07528-MAS12298 Coordinator releases for DPF regeneration-Soot mass < Max. limit_1 Condition met IDE07528-MAS12299 Coordinator releases for DPF regeneration-Soot mass < Max. limit_2 Condition met IDE07528-MAS12300 Coordinator releases for DPF regeneration-Min. limit < engine speed < max. limit Condition not met IDE07528-MAS12301 Coordinator releases for DPF regeneration-Water quantity in charge air cooler < Max. limit Condition met IDE07528-MAS12302 Coordinator releases for DPF regeneration-Internal torque < Max. limit Condition met IDE07528-MAS12303 Coordinator releases for DPF regeneration-Internal torque > Min. limit Condition met IDE07528-MAS12304 Coordinator releases for DPF regeneration-Min. limit < internal torque < max. limit Condition met IDE07528-MAS12305 Coordinator releases for DPF regeneration-Dynamic internal torque < Max. limit Condition met IDE07528-MAS12306 Coordinator releases for DPF regeneration-Positive control deviation motor filling < Max. limit Condition met IDE07528-MAS12307 Coordinator releases for DPF regeneration-Negative control deviation motor filling > Min. limit Condition met IDE07528-MAS12308 Coordinator releases for DPF regeneration-Min. limit < temperature after charge air cooler < max. limit Condition met IDE07528-MAS12309 Coordinator releases for DPF regeneration-Min. limit < engine temperature < max. limit Condition met IDE07528-MAS12310 Coordinator releases for DPF regeneration-Min. limit < combustion chamber temp. < max. limit Condition met IDE07528-MAS12311 Coordinator releases for DPF regeneration-Combustion chamber temp. < Max. limit Condition met IDE07528-MAS12312 Coordinator releases for DPF regeneration-Temperature before turbine < Max. limit Condition met IDE07528-MAS12313 Coordinator releases for DPF regeneration-Temperature after DPF < Max. limit Condition met IDE07528-MAS12314 Coordinator releases for DPF regeneration-Temperature after oxi cat. < Max. limit Condition met IDE07528-MAS12315 Coordinator releases for DPF regeneration-Temperature after oxi cat. < Min. limit Condition met IDE07528-MAS12316 Coordinator releases for DPF regeneration-NSC temperature < Max. limit Condition met IDE07528-MAS12317 Coordinator releases for DPF regeneration-NSC temperature < Min. limit Condition met IDE07528-MAS12318 Coordinator releases for DPF regeneration-Virtual temperature Condition met IDE07528-MAS12611 Coordinator releases for DPF regeneration-Value IDE07528 Coordinator releases for DPF regeneration
[td]
4294967295
[/td]
[td]
4294967287
[/td]
While I have never tried to see if a regen happens below 1/4 tank of fuel, I have seen it documented in quite a few places. Nice to know that soemone has tested it though thanks @Skyliner33Fuel level above 1/4 is not true. My van can start e regen with the fuel in the red zone.
DocumentedWhile I have never tried to see if a regen happens below 1/4 tank of fuel, I have seen it documented in quite a few places.
Mine went into a regen when the low fuel light was on.I thought that was standard 6.1s behaviour - what does yours do?
Yeah my T6 has always been happy to do a regen whatever the fuel level.Mine went into a regen when the low fuel light was on.
Either replacement or could try cleaning. Anyways, the reason for not regenerating needs to be resolved.Thaank you very much for your time. aprichieted. Probably change dpf then?
I don't think yours even have those measuring blocks? It would be under engine adaptations.Would resetting value in measuring block 068 to 30% and then try a forced regen help?
Ain't that the truth!I have found the start criteria for a regen is getting back to your own street after a 2 hr journey![]()
Yeah, if it will do itAin't that the truth!
