I thought the van had to be checked over. Can you advise how to go about this if its just a paper exercise.It's worth noting the T30 is mechanically little different to the T28.
If you saw a T28 and it was love at first sight and found the extra 200kg payload capacity was really important you can get it "up plated" as high as 3.1 tonnes for a couple of hundred quid, a purely paper exercise.
It's also worth bearing in mind that not all specs are created equal. For example, the Startline was available with a "business pack" that bestowed aircon, cruise, autonomous braking, parking sensors, Cat 1 alarm, and which brings the equipment spec close to a highline (main differendes is still lack of colour coding on the exterior trim) for often a lot less cash.
Im pretty sure I must be near capacity when fully loaded ( if not over)
I have upgraded to So low NXT suspension and intend to upgrade the brakes to nutexa in the next 6 months.
