Plastefuchs
Hi all,
I've got an odd issue for you to solve
After changing the transmission fluid after the last major service my T5.1 has developed a persistent issue with selecting any gear when starting up the van - R or D. If the issue occurs and let's say you put it in D, it doesn't have gears and just rolls... if you up the revs it will eventually reconsider what it was meant to do and wacks in the gear, sending a Bing bang throughout the car. Now to the circumstances as to when this happens! It never does it when the engine is cold or at running temperature and only occurs when lets say coolant temp is going down after engine has been turned off for a few minutes (at the shops scenario), anywhere between 40ish to 80ish degree collant temp. Van does not throw any faults when it does happen. But it gets more odd, don't worry! As I have experienced this now for the last 5tkm I have worked out when you come back to the van and start the engine which has slightly cooled down and it has the issue, I can turn the car off and on again and the van has no issue finding its gears... so yes, easy work around but still super odd and annoying! Gearbox runs smooth as between all gears once she is up & running. What are your thoughts? Low transmission fluid after the oil change? Does the gearbox need relearning? Much appreciated your input to solve this!!! Thank you
