Gas regulator
Green Giant
Hi
Looking to order the smev 9722 hob kit later today, there is the option to have either the standard top of bottle gaz regulator or a buikhead regulator that is permanently fixed inside the van, which one is the better option to go for? I’m thinking bulkhead?
Ta
LPG regs state that for a fixed install it must be copper to a fixed bulkhead regulator, then a pig tail (50cm max length I think) to the bottle. Up to you if you stick to the regs unless you want to rent it out.
Also there should be a drop vent at every point that there is a join in the pipe. I only have the one where the gas bottle is tbh. Didn’t fit one under the gas hob.
