Front T6.1 door hinge bolts.(That bolts the two halves of the hinge together)
Mooeee
I have some newer hinges for a T6.1 Top & bottom front drivers and passenger door hinges, but these are missing the bolts that connect the two halves of the hinges together, (once the door has been put back in position on the van). Unfortunately the bolts are not listed in the Car2 prog parts drawings, so just need the part numbers if these can be shared.
The top and bottom bolts are different, the bottom hinge seeming to have a M8 X 16mm fine thread pitch, the top hinge having an M8 X 12mm standard pitch.
Any help with part numbers would be appreciated.
