Replaced the front discs and pads on the van
Look like I have uneven wear now.
Everything looks good,
Clean,
Pads seated correctly
Clips fixed correctly
Just have aboit 2cm of the outer disc tagt isn't been used now.. See pic
Definitely not right. The pad is either too small or seated at an angle so the top never touches. Can you post some pictures of everything, someone might spot something.
That’s not right! Going by the amount of rust (on newish discs!) I’d suggest the calipers are also corroded so not sliding properly. That would mean they are not closing evenly hence only touching properly at the furthest point from the slide pins. Going by the lip that is already forming on the inner edge it’s not as simple as a bedding in issue. I’d strip the calipers and grease the sliders or replace if needed. How come they are so rusted? Do you go to the seaside a lot?
For comparison, my new Nutexa Frictions discs (and pads) fitted 6 weeks ago and 2500 miles in (a few rust spots as not driven for 10 days) - even wear.
