Hi, I have a 2018 T6 Highline fitted with LED Fog/Cornering bulbs, they have given up! When replacing these bulbs do you have to change the box thingy as well? If it is just the bulb where would you recomend?
These are my current dead ones,
These are my current dead ones, View attachment 186881View attachment 186882
Not the correct fog lamps either, they should have a single element and nothing on the end cap otherwise they just dazzle and don't use the reflector correctly.
They are not canbus compatible, but you can use the resistors that you currently have. You'll find that they give a much better beam pattern and longer range as they use the reflector properly.
I am not technically minded by I recently put Auxbeam LED H11 F16 plus as replacement (pure white cornering). Came really quickly when you consider I ordered from aux beam direct. They were plug and play so no compatibility issues on our T6 Caravelle...
