Fitting Fog Lights
tony fraser
hi
i own a 2016 t6 vw multyvan in australia
i want to fit fog lights
i understand that i need
2 fog lights
2 lower bumper grills
wiring loom to connect fog lights
head light switch with fog light function
wear dose the mini loom plug in
and is this all needed ?
There are two ways to do it, you can fit generic wiring that incorporates a relay and just needs a 12 volt feed onto the loom and this will give you manual control of the fog lights, the other option is to use vehicle specific cabling that wires into fusebox/BCM and will replicate factory fit foglights and give you cornering lights etc
Prices are similar but doing the factory way is a little more involved as you need to remove some dash trims to get to fusebox/BCM to connect everything up and will require coding once complete
thank you
2016 t6 multy van i have fitted the fog lights
and would like to conect them as per factory
the wires have conectors on the ends to fit
the plug on the bcm so i need to know whitch
numbers to conect them in
i have the corect light switch and know i will have to have it coded
can any one help with the pin numbers
