CALLAKN Electrician / Linesman VIP Member T6 Legend 6 Jan 2019 #1 do I need new anti roll bar dropper links when fitting the front suspension ? Or do the oem fit...
T6180 Senior Member T6 Legend 6 Jan 2019 #2 CALLAKN said: do I need new anti roll bar dropper links when fitting the front suspension ? Or do the oem fit... Click to expand... OEM are ok as long as there not damaged getting the OEM shocks off. I've not changed my droppings and I'm now lower than b14s
CALLAKN Electrician / Linesman VIP Member T6 Legend 6 Jan 2019 #3 spot on, cheers mark. Buying spring clamps this morning then going to give the fronts a go!! Just hope the top mounts bit go ok!
Fish Joiner VIP Member T6 Legend 6 Jan 2019 #4 T6180 said: OEM are ok as long as there not damaged getting the OEM shocks off. I've not changed my droppings and I'm now lower than b14s Click to expand... What did you change to @T6180
CALLAKN Electrician / Linesman VIP Member T6 Legend 6 Jan 2019 #5 Bit of help in getting this off without breaking? Wipers and plastic ? Cheers
Dellmassive T32 204 DSG LWB SLN PV MY18 & T30 SWB KMB MY67 VCDS User Moderator VIP Member T6 Master 6 Jan 2019 #6 Screw the wiper nut on a turn or two. Wd40 the spline. Pull arm base and tap nut to shock it free. Or use a set of plyers or mole grips across the wiper bottom and nut too to pop it.
CALLAKN Electrician / Linesman VIP Member T6 Legend 6 Jan 2019 #7 So basically it’s just a very snug fit.... Any special tool needed or top mount nut?? I’m on my way to Halfords now
Dellmassive T32 204 DSG LWB SLN PV MY18 & T30 SWB KMB MY67 VCDS User Moderator VIP Member T6 Master 6 Jan 2019 #8 Yes very tight on tapered spline. You could try a puller if they are corroded on....... like this guy. But a bit of force is cheaper. .
CALLAKN Electrician / Linesman VIP Member T6 Legend 6 Jan 2019 #9 They’re not bad.. vans a 18months old , ill put some force into it when I’m back.
T6180 Senior Member T6 Legend 6 Jan 2019 #10 Fish said: What did you change to @T6180 Click to expand... as in coilovers?
Petehelmet Senior Member T6 Guru 6 Jan 2019 #11 Just gently pulled mine out of the way while I undid the plate to get to the top mounts
