I'm in the process of fitting a tracker to my T6.1, it's one that connects to a permanent 12V supply, and has an internal battery back-up. Unfortunately, it only lasts about 1 & 1/2 hours after the power is cut, this is nowhere near enough time to try and locate and recover a stolen vehicle, and if it happened at night, I wouldn't be aware it was stolen until many hours after the battery had died, assuming the main van battery was disconnected to kill off VW We Connect. This would be ok if the vehicle was moved quickly to a final location, but thieves move vehicles to 'cooling off' locations to test whether trackers are fitted, before moving them on to traceable locations.
My question is, has anyone got any recommendations of a battery pack that can be fitted in line with the tracker, that will be on permanent charge from the vehicle, is capable of taking between 12 and 15 Volts charging voltage without setting fire to itself, won't drain the vehicle battery, and can be left doing it's thing indefinitely?
