Hi,
I am almost there with the electrics and I have some final queries I hoep you can help:
1 I have a bus bar under drivers seat, can I connect the bus bar to the chassis or does it need to go back to the leisure battery?
2 I have run the negative from the battery to the chassis is this necesary?
3 I have a victron battery charger for use when on hook up only, it runs directly to the leisure battery. To power it can I cut the plug off and wire it into the 6amp fuse breaker of the consumer units? If so should I add a fuse betweet CU and leisure battery? If not should I run a 3-pin from the CU and plug the battery charger in?
4 The solar panel feeds into a Victron MPPT 75/15 the mppt runs into the blade fuse box (easier than into the leisure battery). do I need a switch to disable the solar or would pulling the fuse be sufficient?
Thanks for your help with this
