EcoFlow PowerStream 800 Watt Microinverter for Balcony Power Plant
been fitted for couple of months,
got the domestic solar bug, so upgrading to larger system.
bought new from EcoFlow 31/05/2023
these are now not available un the UK, and are Hot Property.
(EF have pulled them in the UK due to failing the G98 certification, this is due to the way it "plugs into a socket to connect to the house", G98 states that it needs to be "hard wired", but that's for a "permanent install", which this isn't (its designed as plug and play). so they are in talks to resolve the point. I've been using mine with no problems at all, as is. but if you want to follow G98. then cut the plug off and wire into a spur. - consult a qualified electrician etc etc etc)
and the EU ones are only 600W, so don't bother getting a grey import.
so these are Rocking Horse doodoo.
looking to pass of for what i paid, including my discount.
so £411 for the whole package + delivery or free collection
for:
1x 800W microinverter,
1x window flat PV MC4 cable,
2x Smart Plugs
1x Delta/Delta2 battery cable,
this unit will pass upto 800w into your house and get you free electric.
I've been using with my spare PV solar panels that i use when camping at first. . .
the decided to fit 2x 400W panels on the shed roof..
works with the standard ecoflow APP,
the delta1/2 cable allows you to connect in the battery for solar charge and storage.
for:
2x Smart Plugs
