Ecoflow Delta Solar Charging Oddity
Stueyphoenix
Morning All,
Apologies if this has been addressed before, I did search but to no avail.
I finally found the time to prop my new Renogy panel up and have a go at charging my Ecoflow Delta battery.
The Delta is taking a charge but the wattage readout on the screen is continually cycling between 145Watts ish and 0Watts.
Is this normal or is there a problem?
If I block some of the panel, the Delta readout settles at 65 ish Watts and stops cycling.
According to the manual it will take 400 Watts of solar input. This panel is a single 195 watt panel, the open voltage and current all fit within the 65v and 10am max limits of the Delta.
Any wise folk out there know what is happening or should I just ignore it?
Cheers,
Stu
