Sold Eco-Worth 100ah lithium leisure battery
tomosllyr
As found here:
This is brand new and boxed. Getting rid as I've realised my EHU charger is not lithium compatible. I'm trying to find a workaround to it, but I'm planning on returning this in the meantime and will buy another one when ready.
£200 if someone wants to collect it from Chester area (saving me the hassle of returning it!)
Am I missing something here ?
the link says its £209 brand new ..So save yourself £9 off buying it from the supplier including delivered ...with a warranty 🤷‍♂️
As found here:
@tomosllyr you may need to rethink this....as Jumpship says. 👍🏻
As I've said in original post the plan is to return it. This is simply in case someone local wants it at that price.
An alternative would be to change your EHU charger to a lithium compatible one.
I've explored this. The first solution was to simply switch off the EHU charger component of the PDU and get an external charger to top up from 230v socket when needed. But on the PDU I have fitted there is no easy way to switch off the charger.
The next option is to change the PDU, but the conversion company I've discussed this with would want to completely change the whole wiring in order to make sure everything is up to scratch and I'm not yet ready to commit to this simply to have a lithium battery.
I'm sure I will sort it in the future, but I don't want this battery to be sitting in the shed waiting to be used in the meantime.
Its actually only £191.35 new from the supplier through their Ebay store.
Thanks for pointing this out. In that case I'll just return it.
This thread can be closed mods.
