12mm thick, self adhesive thermal liner suitable for VW Transporter.
Brand new, 4.4m remaining of the opriginal 5m.
Auction listing here.
Cost £129.99 for the 5m roll.
www.deadening.co.uk
Dodo Thermo Liner 12mm - 5sq.m Roll
The best selling Thermo Liner V3 now available as a 12mm option. We have upgraded the flexible closed cell elastomeric foam with improved thermal performance. Thermo Liner v3 features a combination of low thermal conductivity and high water vapour diffusion resistance. The upgrades don't end...
- Latest "v3" Specification
- New 12mm extra thick version
- Efficient low profile insulation
- Easy installation - cut, peel & stick.
- High thermal efficiency nitrile foam
- Significant Noise reduction
- Warmer in the winter, cooler in the summer.
- Reduces condensation
- Acts as a barrier against heat loss
- Thermal conductivity 0.033 W/mK
- Superior Crush resistance
- Improve van interior comfort
- Moisture resistant dense closed cell foam
- Reinforced reflective foil
- Strong Peel & Stick Self Adhesive
- High grade construction
- Flammability tested for vehicle interiors ISO 3795:1989
- Designed in the UK, Manufactured in EU
- Thickness 12mm
- Total area 5 Square metres (53 Square feet)
- Roll/Sheet size 1m x 5m
